Need help: extremely slow speed yaw controls
Thanks in advance for anyone's help.
My yaw rate is extremely low now and can't figure out what could be the issue. The low yaw rate is way beyond the "turtle" speed.
It used to work fine, but recently it changed. Can't seem to pin point what exact things happened to cause this.
FYI.. all the other controls works fine. And I haven't crashed or anything recently.
I did a simple test with the follow me mode, and the yaw rate is normal in turning and tracking.
I have tried the following already.
Updated the latest firmware on q500 4K
Updated the latest firmaware on the st10+
Plugged in the q500 into the computer and calibrated using the interface.
Tested within the hidden calibration menu on the st10 controller.
Hope someone can help.
Thanks again
rrichesin
