http://www.astramodel.cz/manualy/yuneec/MK58_User_Manual_0907.pdf Only for GoPro3+ I found it to be a t great helpHello all flyers,I am back in the air however st10 constantly is trying to connect to video wi fi but never does ,am happy to be flying but still......No Video,,,,Thanks P. S. Camera was working before update
GM saksrd, very possible. I found using cell for true north and setting craft down face north and check with cell. Or on table close to PC. Keep your cell away from craft too and anything that cause interference. hi hi Lites with hi energy bulbs will affect too. Go to GUI page and check all out. I had the same problem and that's what I did. We're talking the Yuneecq500 Typhoon. I'm using the gopro3+. Gud luck and appreciate it if you keep me posted. Been thru some 'wars' with this craft. Best to UCamera is working had to put in default password,however camera will not move horizontally or vertically.could it be perhaps compass needs recalibrating ??
He's right, I forgot about the GUI and Camera Calibration. Sri, good luck and it works.Your compass has nothing to do with your camera.
Open the GUI and do a "Camera Calibration"
See if it helps.
thanks, man. you are the best. i reset by mistake my st10+ and thanks to you i bind again my q with st.saksrd,
Your GPS has nothing to do with your problem.Nor does anything in the drone at this point.
I have no idea about any "Button " you need to press on your Q to get it to bind.Perhaps he's thinking of some other model.
Anyway....
Anytime you shut the box off and reconnect to the usb port you will need to go back into the menu and check "USB Debugging" again to have windows see the box.
To bind your Q to the box, start your Q and let it initialize.Once started, tilt the drone forward to 45 degrees two times. Now look for the orange led on the bottom of the drone indicating the drone is in bind mod. Now go into the box menu and bind the drone.Listen for the drone to beep indicating it's bound and restart all.
We'll get to the camera later. Get the drone to bind first.
