New firmware alive
The way I've understood it is that the dev team is a collaboration between devs from different countries, I've been informed by the horses mouth that as of 2 days ago a bug was still being worked on, and I'm thinking that this will be included into a UK release and the .com site maybe updated with this later...my guess is the .com published dl was preemptive not that the uk site has just not been updated as the have just updated it with breeze details...looking forward to the new camera controls though..
all firmware i posted on 1 post are official :)
please stop writing about DEV team etc:) ( looks like site owners in different country are off or on holiday that is not updated still on UK site)
Downloads - Yuneec
Please see download link on german website :) same as i post few days ago
firm for TH
A <LastModified>2016-08-29T10:58:54.000Z</LastModified>
EU <LastModified>2016-08-29T10:59:20.000Z</LastModified>
BTW
there is new Realsense update
<Key>RS_V_1_10.update</Key>
<LastModified>2016-09-01T08:06:59.000Z</LastModified>
but will wait till Yuneec update it on website :)
and Breeze update
<Key>breeze_V0.1.18_A.bin</Key>
<LastModified>2016-08-09T17:40:06.000Z</LastModified>
<Key>breeze_V0.1.26_A.bin</Key>
<LastModified>2016-08-24T16:55:18.000Z</LastModified>
Just updated mine and also noticed the flight log parsing app not working.
Yep....Mine isn't working either. It was always quite flaky from the start and would crash, on me, on larger files. The app would start out with a map in Chinese and then once you connected to the internet it would right itself. As the map updated on zooming it would also lose the flight path it had drawn. I would like to have this working again...Guess the Android system update might have killed it.
The clock is correct in the Android OS and once you launch the Yuneec app it goes back an hour.... I suppose it might be "fixed" once we go off of daylight savings time?
Also, I've seen that it is suggested to turn off "Advance mode" .... Okay, what do I lose when I turn it off? Or gain with it on? Or has it become a pointless toggle with the new firmware?
No return of the crosshairs for me either on the upgrade.
Hopefully I'll fly a little this afternoon.
For Irish and UK users the official advice I've had from Yuneec UK is to wait until they have verified the update and have it published on their site.
Hal,
Here is the Time adjustment steps:
Press PAD
Press OK
Press SETTINGS
SCROLL DOWN TO & press DATE & TIME
Then unchecked automatic date and time and then below it set your current time.
See if that works for you.
Reactions: zandoli
Hal,
Press PAD
Press OK
Press SETTINGS
I did that...still off an hour.
Bill W.
Easy fix for the clock for now, just set your time zone 1 hour off from actual. If you are in a DST zone you will have to adjust it again when DST changes.
Are you sure that will work ?
Won't the controller still use the GPS time where the craft is at ?
Hal,
Press PAD
Press OK
Press SETTINGS
Thanks…did that…done that… still an hour off. I was thinking of changing my selected location and see what happened. I still thing it is "broken" :)
I was thinking of me physically moving to Central time zone but not certain that will fix thing. :\
Reactions: David Wilson
No one has tried the EU version ?
And it improved WiFi ?
Hi Marco, I loaded EU yesterday and flew it. It works brilliantly. I used the firmware from the US site. I saw no speed up with the WiFi connection. I generally see the camera after a 1min 30 sec wait. It doesn't cut out after that, including raising the landing gear. Hope that helps.
Reactions: Marco Falchi
Hi Christoph,
thanks for the reply.
Interesting that WiFi is not interrupted; But I do not understand if this happens only now, or even with the previous firmware WiFi not interrupted raising the landing gear (and more).
Hi Christoph,
I used to lose picture on the previous firmware, but as time went on, it stopped doing it... Strange. It all seems cured now though.
Reactions: D See Ker
The cruise is cool,basically if you tap the right crosshair up it will make the H move in that direction on its own the more taps the faster it goes leaving you to concentrate on filming instead of flying the H it's a great feature,to stop just retake control with the right stick,each direction on the crosshair makes it go in that direction
Where is the Crosshair on the screen and/or where is it supposed to be if not visible? Some have said it was there before. I have had my H since June and I don't remember a crosshair on any screen.
I've never seen a crosshair either
TyphoonH_Ver2.21_A (and E+J+F) + ST16_V3.1.23.yuneec
standard H http://download.yuneec.com/Typhoon_H/TyphoonH_Ver2.21/Standard/TyphoonH_Ver2.21_A.bin
euro H
http://download.yuneec.com/Typhoon_H/TyphoonH_Ver2.21/Europe/TyphoonH_Ver2.21_E.bin
japan H
http://download.yuneec.com/Typhoon_H/TyphoonH_Ver2.21/Japan/TyphoonH_Ver2.21_J.bin
Australia_New_Zealand H
http://download.yuneec.com/Typhoon_...Australia_New_Zealand)/TyphoonH_Ver2.21_F.bin
China H
http://download.yuneec.com/Typhoon_H/Typhoon+H+special+for+CN/TyphoonH_Ver2.20_A.bin
updated ST16 (ready official release in china 下载 - Yuneec)
http://download.yuneec.com/Typhoon_H/ST16/ST16_V3.1.23/ST16_V3.1.23.yuneec
whats new (eng)
http://download.yuneec.com/Typhoon_H/ST16/ST16_V3.1.23/ST16 Firmware Update Version B23 What's New.pdf
http://download.yuneec.com/Typhoon_H/ST16/ST16_V3.1.23/ST16固件升级B23 What's new.pdf
im not employee and not dev team :) (just the user Typhoon H)
update at yours own risk :)
my H is euro updated with standard:) and
after update can`t connect with H go right-down corner setting switch to team mode , go system setting refresh and will find now H to bind :)
Hi
Can you advise why a difference from usa version and Australian version? Any detriment to using usa version in Australia?
parisaline
