Possible to reverse the 'up' / 'down' direction of gimbal controls?
I was out in Palos Verdes Saturday with my hexacopter.
Here's a video that I took from it.
(The first minute of the video not much happens. I also got the 'up' and 'down' controls for the gimbal of the camera mixed up a couple of times.)
I'd like to have the right stick (when using it for gimbal control in the curved cable cam mode) setup so pressing forward on it would cause the gimbal to move in the downward direction and when pulling back on it would cause the gimbal to move in the upward direction.
Is it possible to do this in the settings without changing the forward/backward actions of the TH using the right stick ?
Thanks for any infi
I don't think it is possible. Like you said if you reverse the Co tool for the camera it will reverse all other functions.
That's what I'm afraid of.
I'd like to be able to setup gimbal movement so I could move the gimbal like an airplane is moved when a stick is used instead of a control yoke.
Bech
