Putting TH manual on the ST-16
I downloaded the TH manual from the Yuneec site into my ST-16's android documents folder so I can refer to it in the field. But it says it can't open, I guess because there is no app to read it. Any ideas how to do this?
Clem
Lawton, OK
The manual I downloaded is in PDF format. There are a lot of PDF readers , free, that are in the app store. Load a reader and you should be able to open the manual.
Clem,
You would need to install Google Play on to your ST-16 in order to install some sort of PDF reader.
here is a link to a thread with instructions and a lot of do and don't do feed back.
http://yuneecpilots.com/threads/how-to-install-google-playstore-on-st16.1305/unread
I do not really recommend doing it as you do not know how it may interfere with the ST-16 performance as a flight controller.
You could convert the PDF files to HTML files then open them with the browser that was pre-installed on your ST-16.
Reactions: DroneClone
wccannabis
