Q500 shows vibration
Washington state
I noticed the last couple of time I have flown that the drone seems to have a vibration in it, I have checked all the props and inspected the drone and found nothing. When I first got the unit I attached the prop guards and I got some serious vibration on the landing gear, I have since removed them but that it what the vibration looked like, I can see the landing gear vibrate pretty good.
any thoughts?
Either out of balance props or a possible crack in one or more of the motor arms.
Cracks can be hard to see and unless your using a prop balancing tool you can never be sure how balanced they are.
Can you feel any play in the motor arms when slight pressure is applied at the motor ?
Do you have another set of props to try ?
Hope you get to the bottom of it.
keep us posted and good luck,
Jafo
Jesster0430
