RAW
Hello everyone,
I am looking for any info on RAW files for stills. I set using the parameters in the guide and no avail.
I also read somewhere setting the video resolution to its lowest setting to use RAW? Any input ould be greatly appreciated. Also, please excuse me if this all ready a posted question.
I do not know if there are differences in the setup between the Breeze and the Typhoon, but in the H,
you must be in photo mode to change the JPG/DNG settings. Also you want the video settings to be
at 4K, to give the full resolution 12MP images when in photo mode. Your RAW/DNG images should
be about 23MB in size off of the SD card.
Yes what he said, you need to be in photo mode before you can use DNG
Reactions: GerryR
Thanks! I've tried it and still nothing. This is a screen grab of the only option
The scene mode setting is a different setting than the photo mode setting. The photo mode setting,
determines what file format your photo files are saved as, and therefore the final resolution
Reactions: Rustyflyer
One more slide over there is General Camera Settings. You will see Natural, Saturation,RAW & Night. Pick RAW and that should be what you want. Tried to screen capture my phone but its a pain in the butt
Reactions: GerryR
Thanks! This?
That I am not sure of. Just referencing from the app as I don't own the Breeze. Just trying to help out if i can.
Reactions: GerryR
I am interpreting from your screenshot, but I would guess that you should select "Ultra High" in the Photo settings.
I don't think the Breeze shoots any kind of RAW files. It can only take pictures in JPG format. The RAW setting is a picture profile, not a file type.
Reactions: GerryR
Correct. Reread the very small print in owners manual. Thanks!
Makes sense as the Breeze is being marketed to the Instagram selfie user
Reactions: GerryR
That was my first thought, but then seeing RAW in one of the menu's I got excited. Experimenting with it more today and jpegs are a decent quality for my needs right now.
DHYradio
