Real Sense
New to the Typhoon H and having trouble is getting the Real Sense function to work. Each time I flip the switch to On I get a message on the screen Failed to Start.
Had it both Angle and Smart Mode but keep getting the failed to start.
Tks,
Tks,
Have you put a check mark in the Real Sense box yet on your ST16 display to turn on the RS module?
Power up the ST16. Hit System Settings and then Ok. A screen will pop up to bind, mess with the channels, etc. Look for the "Other Settings" option and press that. That will take you to the screen where you select how your ST16 displays distance (metric or feet) and other options, including the RS module. That box MUST be checked for your RealSense to be on.
Check that out first.
Reactions: Rayray
Bech
