Replacing the stock lens mod done
First all credit to Jorge Castillo13433082_1035965906480309_3388350886183445563_o.jpg
I see a member of one of the Yuphoon H Facebook group found a company that replaced the len on the CGO3+ with remarked improvement in sharpness and removed the lens distortion Focal Length 3.97mm, But cost is high nearly $140 , but you are able to buy a similar lens with very similar spec from http://www.gitup.com/en/cameras/42-1...-for-git2.html for $60 , I for one would like to replace the current lens Yuneec sells with the Cgo3 and and Cgo3+
I feel this mod would bring the Yuphoon H inline with the other brand .
here is the link to a DNG https://drive.google.com/file/d/0B9e...w?pref=2&pli=1
Reactions: Forrestt
Sorry but the links do not work, just says page not available and file does not exist
I don't see a resolution problem with my Q500 4K or my Typhoon H. Did you remove the protective clear cover from the lens??
I can count the shingles on my house from 200 feet, on the original. Seems to loose a little resolution on upload with compression. Not bad for 12 mp.
Looks even sharper on my iMac 5K monitor.
DHYradio
