SD Cards
I just bought this last night PNY and should be getting it today. I have the 128 I bought but found that its not as fast as the one I bought last night.
Amazon.com: SanDisk Ultra 128GB microSDXC UHS-I Card with Adapter, Black, Standard Packaging (SDSQUNC-128G-GN6MA): Computers & Accessories <- good but not as fast as I want.
Amazon.com: PNY U3 PRO Elite MicroSD Card - 64GB - P-SDU64GU395PROE-GE: Computers & Accessories <- this is supposed to be 90 ish read and write and its cheaper than some others that run this fast
Fast write times is the key.
I agree with SF. SanDisk make a great card with hi transfer rate. Any card must be UHS-I class
Is there a way to format it once in the camera? I had a look last night and can't find anyway
I formatted mine in the st16. Now with that being said, that was tricky. That stupid SD slot is so hard to work with. I used a jewelers slot screwdriver to get it in and after fiddling with it for almost 1/2 hour I got it to work. Some people have said they get the card in but can't get it out. You would be better off just format it on a computer and then start shooting and the folders get automatically created on the card.
In the UK locally to me I have two choices...
Both Sandisk:
32GB Extreme - Read 90 MB's Write 40 MB's - £14.99
32GB Extreme Plus - Read 95 MB's Write 90 MB's - £19.99
For the extra cash would there be any actual advantage in the real world going from 40 write to 90 write when shooting 4K?
Both Sandisk:
Yes, get the Extreme plus. Faster the better. Thats how I would do it. Reading is not important for 4K its the writing thats important.
No problem, from what I've read both are 4K compliant but for the sake of a fiver I'll go for the better one.
Surely there must be a way to format a memory card once it's in the camera though..... It's always best to get the camera you're using to format a card.
I purchased a 64gig SanDisk Class 10 U3 from B&H for $29.99. Make sure you buy the U3 and not the U1. The U1 is a little cheaper but is not as fast. Yuneec recommends U3 for 4K.
mexstoragesystem
