H will return to home after 10 seconds if it loses GPS signal, not video signal ! If you are concerned flip the Flight Mode switch to "HOME" the switch that selects Safe Mode/Angle Mode and Home mode, BUT ! make sure you are high enough up to clear any obstacles on it's way home ! If you are 30' or below it will stay/raise to 30' and return a direct bath to home(YOU/TRANSMITTER) if you are over 30' it will return at the height you are atWhat happend if I loose contact with my typhoon H (to far, to height) ?
Will it come back home alone ?
Do I have something to do, or just wait ?
Anyone has tested that ?
Yes to "Home" mode, if you can't wait 10 seconds to see if it will notify you of a auto return to home activation. yes you can cancel anytime by flipping the flight control switch back to Smart or Angle modesthank you.
So if I loose video signal, I just have to switch to RTH mode. Can I cancel the RTH when I want ?
I think you meant Control signal and not GPS. If it loses GPS, home mode won't work.H will return to home after 10 seconds if it loses GPS signal, not video signal ! If you are concerned flip the Flight Mode switch to "HOME" the switch that selects Safe Mode/Angle Mode and Home mode, BUT ! make sure you are high enough up to clear any obstacles on it's way home ! If you are 30' or below it will stay/raise to 30' and return a direct bath to home(YOU/TRANSMITTER) if you are over 30' it will return at the height you are at
400' AGL (Above Ground Level) Hopefully in a near future update!Would be nice to be able to adjust the RTH to above 30 feet (so it climbs to whatever set and then returns home)… So far have only had to use it once and I was pretty high. In a mountainous area, I found that the 400Ft limit is based, I believe, on where I am standing and not where the H is flying. I tried to climb, lost contact…But, it returned safely.
can the 400 ft limit be increased in the GUI?
