ST 10 + battery warning
My question is regarding the life of the ST 10 battery. How low can the battery charge become and still be safe to fly and is there a warning when the battery of the ST 10 gets too low as there is with the Q500?
i fly 3 batteries and when i down load the info from the SD card it the battery is a little over half full , then i recharge the battery and i wont use it until i go out to fly again . if you charge the battery before you fly you may get a little longer flight time . i don't know if the ST 10 will give a warning , now that's a good question .
Stone
