  1. Reasty
    England UK
    Ok so it takes forrrrrevvver charging the st16 from the usb port on the side of the bundled charger,has anyone charged there st16 off there android phone charger/ and is this considered to be safe and ok as id imagine it'll charge alot faster.
  2. JCFlippen
    Cardiff-Wales UK
    I charge the ST16 with a 2.1 amp USB Ipad charger without problems.
  3. Reasty
    England UK
    splendid thanks for the comfirmation,i thought it would probably be fine as after all it is just an android tablet but wanted to just double check.
  4. Dirk
    Hasselt Belgium
    I use my Turnigy accucell 8150, works fine. I use the lipo/lilo program. takes about 1,5h .
  5. humboldt 707
    Go for it,I also charge my st10 batteries on the side also, if there's an adapter you can pretty much charge anything on the side,as long as you have decent safe charger.
