ST16 Display Black when on but blue light OK/No battery indicator while charging.
Hello all,
Sorry for the dumb question, I suffer from Post Traumatic Stress Disorder and serious rib injuries so I tend to get anxious when encountering issues like this. I obtained a Typhoon H with Real Sense today. When I charge the ST16 display via UBB through the main battery charger (which is working charging the drone's main battery) and tap the ST16's display nothing happens (screen dark). When I unplug the mini-usb from the ST16 and turn it on the blue light is solid and if I press the left/right pads on the bottom I hear a beep but the screen is dark. I unplugged the ST16 battery, waited and plugged it back in and still same issue. Thanks in advance.
Hello all,
I had a similar issue on my Pro RS. Ended up sending radio in. They were very quick to fix it. New mobo and she's was sitting pretty
Jesster0430
