  1. Burntpixel
    Georgia
    Several people including myself have been seeing issues when connecting the ST16 HDMI port out to an external HD field monitor.Of the 2 professional field HD monitors I own,only one would sync with the video feed from the ST16.
    Even when working,the video image on the ST16 would go blank yet the video image would still show on the external HD monitor.Tapping the ST16 screen twice would bring the screen back up,but it would once again go blank after a few seconds.
    As this is happening to multiple users,I think this is a hardware/software conflict issue with the ST16 and 3RD party external HD monitors.I just want anyone reading this to understand that if you plug in an external HD device into your ST16 it may or may not work.
    This is rather concerning as the ST16 HDMI out port is a major reason many have purchased the H.I believe Yuneec needs to address this issue asap.
  2. Burntpixel
    Georgia
    There are 2 versions of the ST16 currently out.
    1- TILT,PAN MODE,OBS,FLIGHT MODE and LANDING GEAR switches are chromed and metal
    2- TILT,PAN MODE,OBS,FLIGHT MODE and LANDING GEAR switches are rubberized.
    This indicates when within the production run of the ST16 the time frame of manufacture . The rubberised switch version apparently is the earlier of the two.
    The HDMI issue occurs with BOTH variations of ST16 controllers.
    #2 Burntpixel, Jun 7, 2016
    horizontal likes this.
  3. Yuneec_Usa
    Ontario, CA
    We apologize for the inconvenience I have forwarded your comments to our product manager and engineers.
    Jared likes this.
  4. Allan
    So, I ran this test just now. ST16 with silver switches, I haven't done any firmware updates. The secondary monitor will connect to the ST16 and display and stay on. It will also stay on in Pad mode. However, in Flight Mode, if I double click to display the video feed full screen, the ST16 monitor turns off in 5 seconds, but the secondary monitor always has a video feed. Touching the ST16 screen turns the ST16 screen back on, but again for only 5 seconds.
    I'm sure this is something Yuneec can fix in a future firmware update.
  5. Gurusonwheels
    I have flysight 01 goggles they have problems connected to HDMI of st16. They have 1/3 of bottom screen shifted out of align when connected .
  6. PatR
    Home in May
    I'm another that has experienced this problem with the chrome switch ST-16. When I made the decision to purchase the H, having HDMI out was, and still is, a large part of my reason for buying it. When I build a camera rig, always a hex or greater, one of the features I install on them is HDMI out, with another a 360* gimbal. Not having functional HDMI out significantly reduces the benefits that were advertised as part of the Typhoon H imagery features. The H flies nice but lots of multirotors do that.
  7. Burntpixel
    Georgia
    Sorry to hear you too are having an issue. This is beginning to looks like it affects all ST16 conrollers.
  8. Burntpixel
    Georgia
    Have a functioning HD signal out to ALL HD monitors was very much a major reason in buying the H. As it stands now,the HDMI out is all but useless.
  9. Burntpixel
    Georgia
    When you go to video mode only on your ST16 controller screen,does it go blank?
  10. Andyzonk
    Newquay - Cornwall - UK
    My ST16 seems a bit different. It's a Chrome Switch Model and I use the HDMI connection with Headplay HD FPV Goggles. With the Headplay Goggles connected, the ST16 flight screen stays Active. If I switch to PAD and play a Video, the ST16 Screen switches off..........Just tried this with a Monitor - The same.
  11. Burntpixel
    Georgia
    When you say the ST16 flight screen stays active,do you mean the video image and telemetry overlay are both present on the ST16 screen and Headplay? If so, double tap the ST16 screen to just view the cameras feed without telemetry/controll overlay. When you do that does the ST16 screen go blank?
    Jacques BRET likes this.
  12. Andyzonk
    'YES' to your first Question..........'NO' to your second Question.........The only time the ST16 screen goes Blank (with HDMI connected) is in PAD Mode.
  13. PatR
    Home in May
    Do not under any circumstances switch to tablet mode while the H is in flight. I have already done this and link with the aircraft is immediately cut. The aircraft goes into RTH mode and comes to a point at the Safe Circle distance and hovers.
    yuneec53 likes this.
  14. oliver
    France
    Hello,
    i confirm you the same problem. Out HDMI no works with secondary monitor. It is anormal.
    idem PatR
    "When I made the decision to purchase the H, having HDMI out was, and still is, a large part of my reason for buying it."
    the only time it works is on a Dell U2413 in office
    #14 oliver, Jun 30, 2016
  15. Dragonflyerthom
    Gurdon, Ar
    Now let me get my head around this. The hdmi on top of the controller isn't working, not the miniusb on the bottom of the controller?
  16. PatR
    Home in May
    In essence that is correct, although it is not known if the problem is with the HDMI port itself or something in the communication protocol.
  17. oliver
    France
  18. Filipe
    I need to have normal display in controller but put outside to a monitor the image without settings and other stuff we need to fly? is Possible? I have the ST16 with chromed bottons!
    I try to connect with Hdmi and i made double click stays in second display clear image with a cross in the middle only and in the controller after 5 seconds turns off!
    Thats a big problem because i need to make a work were will be display in real time what im filming so i need the second display with clear image but normal image and controllers in the screen of ST16.
    If can anyone help urgent
