Yeah, that's a little steep given how little these things weigh...sort of a ripoff IMHO. On the bright side, looks like the $ is firming up against the GB Pound, so that should at least help a little.Have to find a US seller, need one on top for night flights
$17.82 US funds shipped.
Don't understand why you did this. Won't the camera pick this light up if you pan 180°?I went big and go one of these in white and velcroed it to the underside on that hump a the back.
Lightman Personal Strobe and LED Light Products [ETIP, Inc.]
Thanks hunterNo it does not in the day time. Sunlight makes it so I have never seen it.
I don't fly close to solid objects for it to reflect off of.
It might after dark but your not supposed to fly after dark per the FAA rules. It would not affect the "quality" but might show up as a light area in a still if you could catch a flash, maybe 1000 sec or show flashes in a video.
I suggest you don't try it or until you do, refrain from making statements that it does.
Just sayin.................
I've always used a pair of Strobons with my home builds. In those cases, I used the version that allowed me to tap off the Rx for both power and on/off control. Always liked the results. Someday, when I get my Typhoon back from Yuneec Europe (I have no hopes of seeing it back probably until August), I may get the nerve up to remove the cover, look for the Rx, and see if it's possible to wire in the strobes like I've always done. As the ST16 has an Aux switch that is for the moment unused, this might be possible to trigger the strobes on/off remotely. It's just a thought in the back of my mind for now, however. Reality is I've got more important things going on (family, kids, and the business) and really don't have the time to tinker around like this that I used to.They are not expensive in relation to invalidating your warranty by poking around to find a power source for other units. I have fitted Strobons to all my machines and they have saved the day re orientation many times.
LOL! Are you freakin serious? Look up the word "lame" in an English dictionary.Cheap,Good and light weight built in rechargeable battery USB charge, clamp it on the typhoon H leg below video link
自行车灯后尾灯USB充电 双色红蓝LED警示灯 山地车配件夜骑行防水
Why bother of marking the "H" with LEDs etc? Just look at the "Green Arrow" to find out how its flying! When the Green Arrow is in the top the "H" is facing away from you - and vice versa!Hi John - I got one of these after your last post. Excellent tip - Thanks
