It is always a bit scary to handle those energy packed bricks that can keep a 2 kg drone in the air for 20 minutes... Having two (or four) of them burning down simultaneously is really a nightmare.I still think these are a seriously bad idea. If you have two (or god forbid) four large lipo's in a charger and one goes up in smoke you are going to have a major fire on your hands that you will not be able to put out. The smoke would be enough to fill your house, kill anyone who cannot get out and destroy everything.
I think it would be a far better idea to have a central charging unit with remote docs that could be placed at a distance from each other.
Mc, do you know of any confirmed examples of Yuneec batteries going up in smoke on a charger?
Thanks, good idea. Will possibly build such an indoor (garage) "charging station" sooner than later, maybe this weekend...simple battery bunker of cinder blocks and cement board for the base with bag of sand over head of the charger ready to drop flood sand on the lipos should they go into meltdown. fire melts the sand bag the bag gives way emptying the sand on to the fire.
Yuneec batteries are not unique!!!
It is obvious from the amount of questions asked on the forum regarding batteries and everything to do with them that a lot of people have no idea of the danger they present.
No-one will ever convince me that mass close grouped charging of potentially explosive materials is a good idea.
Do you have the impression that charging the ST16 via the USB port takes longer than with the orginal SC4000-4 charger?I have the same one and it works very well!
