https://www.facebook.com/yuneectyphoonh.eu/?hc_ref=NEWSFEED&fref=nf
From facebook, a valuable European source.
Yuneec Typhoon H EU
1 uur ·
GPS FAILURE & FIRMWARE UPDATES:
Thanks to
Sami Rautaneva, a customer and supporter from Finland I now have the necessary data to understand and correctly explain what I already knew...
There are those who've never had an issue with their H until a Firmware update...
For no apparent reason the H either drifts in flight or behaves irraticaly at low altitude or on landing?
Well here's why...
There were apparently 3 hardware revisions of the GPS units by the manufacturer and Yuneec keep fitting the latest revision to their newer aircraft.
It is quite an advanced unit but there is no update port included by Yuneec once they've integrated it into their Compass and Barometric Pressure Sensor Units as a GPS Combination Module.
Only Yuneec can factory flash firmware to the GPS unit and once done is not upgradable because there is no update port on the Yuneec GPS/Compass & Barometric Pressure Sensor Combination Module.
The latest Firmware Variants for the H are not compatible with the preflashed firmware on the older revision GPS units included on the oder GPS/C & BPS Modules; specifically with regard to the GPS unit.
So swapping out the GPS Combination Module is pointless unless you're replacing the old unit with a newer or Current Reversion.
Yuneec aren't telling anyone this because they probably don't know themselves?
Those lucky enough get a new aircraft or a possibly a GPS Combination Module Upgrade; the others suffer in silence.
Also the GPS unit requires somewhere around 15s of satelite-lock-on-time to correctly orient itself.
So it's always advisable to wait around 15s after GPS Lock before takeoff.
Additionally satelites continuously update their own data and correction algorithms; as a result a significant geographic move or period of non-use requires a download of "corrected/updated" satellite Information.
This can take anywhere from 5-20min so again if you haven't used your aircraft for a significant time or you've moved a substantial distance geographically; you need to leave the aircraft alone for around 15min with full GPS Lock before takeoff.
This allows the GPS unit to efficiently update itself before takeoff rather than in-flight; which is not ideal.
Couurtesey Esteves Carvalho
please visit his
facebook and feel free to help his
initiative to pursuade Yuneec doing nice things
