  1. Wileytrigger21
    Spring, TX
    Hello all,
    I thought I would start this thread to create a list of items that we would like to see Yuneec implement in firmware updates. Please like if you agree and add your suggestions. Maybe Yuneec will take notice. Lets keep the items feasible.
    1. Speed control on CCC and POI
    2. Ability to stop at waypoints on CCC
    3. Timelapse capability on Camera
    4. Auto exposure bracketing
    5. True manual white balance
    6. Ability to save camera settings
    7. Open up SDK so dronedeploy, pix4d, etc apps will work (just dreaming on this)
    _____________
    8. Programmable RTH height
    9. Better connectivity
    10. Wizard as camera target (while using ST16 to pilot)
    #1 Wileytrigger21, Aug 12, 2016
  2. Goh
    Goh
    8. Able to change the camera (photo and video) setting during the flight
    9. RTH setting
    10 Able to take photo during the video recording
  3. Reasty
    England UK
    10. more fixes for slow wifi connectivity and disconnects during flight
    Wileytrigger21 likes this.
  4. Wileytrigger21
    Spring, TX
    We can change the camera/video setting. Do you mean both at the same time?
  5. Brandon Lowe
    Eagle ID
    Your list has a lot of good things on it and in reality it is all stuff that could be fixed with a firmware upgrade.
    Can you set the altitude in CCC? I have not tried it yet but someone said not to do it al low altitude. If not that should be added to the list.
    Another thing I would like is to see them offer an upgraded camera, does not need to be CG04 level but just better. I would be will to spend $$$ on it and I'm sure many others would too.
  6. Wileytrigger21
    Spring, TX
    Yes, you can set altitude. You have to fly the points or try Eric's CCC editor. I love the idea of an upgraded camera.
  7. Sami Rautaneva
    Wizard as a camera target.
    Wiz likes this.
  8. Wileytrigger21
    Spring, TX
    I'm not sure they can do that with firmware. Great Idea tho! added.
    Wiz likes this.
  9. OnTheRopes
    Peak District, UK
    Manual camera settings on a redundant switch
    Canera settings that don't default back to auto when you reboot/change battery
    Sami Rautaneva likes this.
  10. methodus
    Many, many ideas for my app... *making-notes*. Go ahead, don't feel interupted .
  11. PatR
    Home in May
    I'll go along with RTH settings but you have been able to change camera and video settings during flight since the CGO-3 camera first came out on the Typhoon 4K and Chroma. Those control functions were also present on the CGO-2. Make it a point to change camera and video settings during flight to bracket photos and alter image quality as conditions require. It's not hard to do.
    Adding the ability to take a photo while in video mode is totally redundant and an unnecessary complication. You can pull a screen grab from any portion of a video during playback at home.
  12. Wileytrigger21
    Spring, TX
    Ya..I was scratching my head on those two.
  13. Wileytrigger21
    Spring, TX
    I just became beta tester on your app. Cant wait to try it out tomorrow
  14. THoff
    A couple of enhancements for RTH:
    1. Make action when remote control is lost configurable (hover or RTH -- both have valid use cases).
    2. Allow RTH return height to be set up to maximum height that the TH is configured for.
    3. Allow RTH to automatically enable Smart Mode + Obstacle Avoidance to allow a TH with RealSense to navigate around obstacles.
    I'd love to see IPS fully enabled so it can hold position, not just height.
    I'd love to see RealSense work in Angle mode (obviously only in the direction that the drone is facing)
    I'd love to see RealSense work in the absence of GPS lock. RealSense and IPS would be great for indoor flying, but requiring GPS prevents that.
  15. PatR
    Home in May
    If you have an aircraft that is stable without GPS you don't need IPS, just good fingers and turtle speed.
  16. Manny D
    I thought the wizard was usable as a camera target. Isn't that what the water proof sleeve is for. Skiing or kayaking and the H follows the Wizard?
  17. Wileytrigger21
    Spring, TX
    Talking about being able to pilot with the ST16 and use the wizard as follow/watch me
  18. THoff
    Yes, that is one function I was hoping for but that isn't currently possible -- free-flying the Typhoon H with the ST16 while the camera automatically focuses on the Wizard.
  19. Wileytrigger21
    Spring, TX
    You know...I wonder if you bound the wizard to the H and camera without turning on st16 and then turned on st16 and just bound it to the H not the camera....hmmmmmmm
    (Grammer...horrible run-on..lol)
  20. BillyTexas
    In team mode with the wizard and st16...i think it will work.
