- Joined
- Jul 5, 2016
- Messages
- 115
- Reaction score
- 56
- Age
- 58
Well at least your yaw is stable while its sitting still. .2 is acceptable for pitch.
Does it toilet bowl?[/QUOT
Some updates:
I hooked up the H to the Typhoon GUI via the USB cable.
I noticed 2 things are wrong.
#1 the pitch is off by 2.0 despite multiple accelerometer calibrations on a level surface.
#2 the yaw upon close observation is constantly varying in the clockwise circle at a rate of about 1 degree per 2 secs. (Which makes sense why is would t bowl the air)
The thing is registering rotations when it's perfectly still!!!!!
Can anyone with the new firmware and typhoon GUI hook up their typhoon and observe the yaw and pitch on a level surface and report back the readings.
I am going to figure this out. That little gyro in the center is probably the problem.
Ana Rosa
Here is the video I made Typhoon H GUI Test on YouTube:
Yesterday believe I had a toilet bowl. See video of the last 2:20 minutes. Most say that I did not calibrate my bird before the flight so can not tell if it is an pilot error.
There's my same problem ...you can't have that yaw increasing while it's still. That's the cause of the toilet bowl. What's the firmware you are running ?
That's the latest, my next step is to try to revert back to the old firmware and see if the problem goes away.See picture
Guys after the firmware update i get unstable flight after as little as 30 secs of staying in the same position. Ive read all the posts and it seems no real solution exists tomsolve it aside from tne manufacture replacing the electronic controls.
The first time the toilet bowl occured i did the obvious thing which is attempt to stabilize through the controls in Angle flight mode. It spiraled and bringing it down without a crash was impossbile. It was a thick grassy bed so it flipped as the landjng gear touched but no damage.
I read several threads and although no one has solved it despite compass calibrations facing north and accelerometer calibations on a level surface someone did suggest turning off the gps while in flight.
I tried it and its a Lifesaver. If your drone is toilet bowling out of control and your runnjng the new firmware on the st 16. Deactivate the gps and flight will become stable enough to land. It will drift a little due to wind but much more landable than a crazy spiral.
Now for those who dont have warrenty do you think replacing the gps board will solve the issue.
I am curious if its a bad board or if its firmware related.
Thanks for your thoughts.
Has anybody found out if it's the update that's causing the dunny effect, if it is I won't bother with the update.
