  1. bowhunt
    Denmark
    For Information before you see the video. I have now tested Typhoon H Real Sense, without cheating.
    I have chosen to use ST16 with Camera setting on Gimbal Pan Mode in Global Mode. With this setting, try the camera to point at ST16, while Typhoon H, always fly forward, so Real Sense can dodge objects.
    At the end the crash, due to the came down to 2 meters in height and made IPS to automatically lifted off as one of the rear propeller that a branch. There was no damage, only 4 new propellers.
    In my opinion, then meets Typhoon H Real Sense my expectations for it.
    The last 10 minutes are blank. Wrong uploaded to Youtube
    #1 bowhunt, Aug 17, 2016
    cyberhiker, yuneec53 and QuadBart like this.
  2. abinder
    The only place is saw blank was the last 10 minutes like he said.
    There's times it seem like it was just in follow me mode and sometimes it appeared to be in watch me mode.
    The RealSense seemed to work really well to me.
    Let's see the Phantom 4 'fan boys' be able to have it track them going through trees like that !!!!!
  3. sdharris
    13 minutes in it was very lucky not to have crashed. I'm not overly convinced but it did survive a rather harrowing flight amongst the trees.
    bowhunt, you should use the youtube video editor function to remove the last 10 minutes of the video rather than just leave it blank.
  4. bowhunt
    Denmark
    [QUOTE = "sdharris, post: 42.117, medlem: 816"] 13 minutter i det var meget heldig ikke at have styrtede ned. Jeg er ikke overdrevent overbevist men det gjorde overleve en temmelig rystende flyvning blandt træerne.
    bowhunt, skal du bruge youtube video editor funktion til at fjerne de sidste 10 minutter af video i stedet for bare lade det stå tomt. [/ quote]
    Hvordan gør jeg med Youtube Editor? Online?
  5. sdharris
    Yes online. If you are logged in to YouTube, open your video and underneath you will see icons for info and settings, enhancements, audio etc. Under enhancements you will find a trim option which you can use to remove the last 10 minutes.
  6. Sticks
    Denver area
    Dense trees plus stout gusty windy conditions...I'd say it works as advertised.
    abinder likes this.
  7. bowhunt
    Denmark
    It is not advertised. It is true , and I'm only amateur.
