- Joined
- Mar 5, 2017
- Messages
- 54
- Reaction score
- 5
- Age
- 71
Hi Pilots!
Today I first time flu our second "H" (pro, RS), latest firmware! Compass calibration done!
Weather perfect. 2 m/s. 5/8 overcast.
Landing gear: T/O and hovering in 3 meters...gear up...no joy. Left leg moved about 3 cm, right leg not at all. It needed 3 or more attempts to get it finally up! All other attempts worked with no problems. Will try tomorrow again and see!
Brand new "H" - did anybody of you experienced the same?
Twitchy: many of you talking about this. Ok. What I observed is following.
In turtle mode, even with very sensibel stick movements the H is really twitching! As further I higher the speed in direction rabbit, the less the twitchy reaction. Basically after a 5th of the way to rabbit twitching is gone. On both of our H's same.
Something else: Shall I call it twitching? Take off in turtle/angle/OA off! The H (ours) will lift off up to about 15 cm and then jumps about 10 cm up and then continues the climb normal. This reaction cannot be observed with higher speed selected. I am not nervous on the left stick. Did you made the same experience/observation?
Just waiting for any reply on this!
Cheers and cya!
Cheers and cya!
