Typhoon G Dont Take Flight - Slow Motors
Fau
Hi everybody, could anyone help me? I'm in trouble with my Drone Typhoon G. I can connect the remote control with the drone, the connection between the two is done successfully, I can see all the motors working, but when I try to take flight I realize that the motors do not work with the required speed, I move the controls and I realize that it works, Turn right and turn left and turn up and turn down but do not take flight. I have upgraded both the Software (GUI) and the Controller Firmware, but the problem continues. Could someone help me please? Thank you ....
Have you tried moving the Right Side Slider switch to RABBIT MODE?
Have you flown this drone before and everything was okay?
And I see from another post you made you are having trouble with the Gimbal Also?
Reactions: Fau
Thank you for help me Wingshooter. Yes i have had flow befor, normally before, it was ok and I use those rabbit and turtle mode for landing and flying but now, I switched both and do not make any diference with this problem. Yes i ahd a ligh crash i mean its was a "hard" landing and then the gimbal stoped work, after that i coukd fly normally without the gimbal. Iam not very worryng with the gimbal because Iam thinking to buy a CGO3 camera... if i can fix the gimbal tha will be ok . Thanks
Well there are several things to check.
Could be the ST10 Controller Calibration needs to be performed. There is a Test inside the ST10 Controller to see if all the sticks and buttons are working correctly on the ST10 Controller.
Here is a link:
Here is a link:
Hi, i did that test all test, but i still heve the problem
trienchieu369
