Typhoon H - Battery Voltage Tester
Anyone try a battery voltage tester out on the Typhoon H batteries? I want to find a way to check the battery voltage without putting the battery in thy Typhoon H.
Multi Meter on the outside connectors for a total. Of course that does not test the individual cells.
Thanks for the response. I was looking for a way to use an existing LiPO voltage tester so I could check each cell and total. I will try out a multimeter.
Look around here. Some really smart members posted a mod (hack)to allow you to do just that with the existing charger. Supposed to be working so can;t look up but you will find it.
simsone
