  1. BobW55
    BobW55 Moderator
    Staff Member
    Melvin Michigan, In the thumb
  2. DroneClone
    Texas
    It says "Access Denied, not Allowed to View this Page" WTF!
  3. BobW55
    BobW55 Moderator
    Staff Member
    It let me in but before I could grab my phone to download it gives me the same message now. Darn it all
  4. DroneClone
    Texas
    Sucks! Guess they can't make their minds up ! LO:mad:L !
  5. Johnny Cage
    it is back up I just got it..........
  6. Royce Sims
    I downloaded it this morning also , along with firmware updates .
  7. DroneClone
    Texas
    New firmware or the original boxed one? Someone please explain to this old wounded DJI Veteran, what a GUI is and lead me to instructions on how to update firmware! I take it GUI must be a program that downloads the new firmware to you Yuneec's
  8. raymond captuo
    remsenburg ny 11960
    LOL....you asked what i was afraid to....i guess its going to be a totally different learning curve coming from DJI....mine is coming wednesday...i will try and take my time...but i don't have much patience when it comes to reading manuals....
    DroneClone likes this.
  9. WanderLust68
    the tutorial video explains how to upgrade the typhoon using the sd card....ie...insert sd card into typhoon, power on transmitter, power on typhoon and perform update.....how do you update the transmitter itself? Use the sd card in the transmitter or via the typhoon's sd card?
  10. NoCoOutdoorGuys
    GUI is Graphical User Interface
    Link to firmware update procedure:
  11. DroneClone
    Texas
    There is not a hell of alot to read, informative wise in general, but yes, do read it , as it is quite a different breed than a DJI, especially the controller and APP functions!, but you will fair well, I am confident. No one wants to answer my post on the "Mushroom Antenna" that came disconnected in un boxing, not by the threaded part that screws onto the ST16, but the swivel part that pushes into the screw on part!:(
  12. DroneClone
    Texas
    Is the firmware new? or just the out of box one?
  13. Typhoon Charlie
    Missoula Montana
    DC, a GUI is a graphic user interface. It is a program that will let you communicate with the H and make changes to the settings. Same as what you use on the Phantom. If you are running Windows 10, you might get a warning of potential harmful program being installed. This is because it is not properly signed by Microsoft, don't worry.
  14. Cilent1
    Florida Gulf Coast
    Yuneec firmware update instructions...
    Nvrmnd...OutdoorGuys posted same link above.
  15. NoCoOutdoorGuys
    I'm not sure what version firmware people have (I don't have mine yet).
    The page seemed to have changed since I last looked at it:
    • Improvements to ultrasonic obstacle avoidance system performance.
    • Improvements to gimbal control in pan mode.
    (Date: 5/19/2016)
  16. Typhoon Charlie
    Missoula Montana
    When using the speed controller status test, make sure props are off. I don,t know if a warning appears but this can ruin your day.
  17. NoCoOutdoorGuys
    I hope they get around to making a OSX version before mine gets here.
    m5zealot and PRnNJs FINEST like this.
  18. DroneClone
    Texas
    Is the date 5/19/2016 I see above the firmware date? if so I received mine on 20th , so this would definitively be new!
  19. Typhoon Charlie
    Missoula Montana
    When you connect your H to the GUI it will tell you what version you have.
  20. Losoul
    The instructions are for update using de SD Card. Can it be done directly using the GUI? If so, how (any instructions)?
