If you click on file/firmware update on the GUI you can choose the file you downloaded and it should update. Thats what it looks like, but like most here I am still waiting for mine, so hope this is right.
The instructions are for update using de SD Card. Can it be done directly using the GUI? If so, how (any instructions)?
Is the date 5/19/2016 I see above the firmware date? if so I received mine on 20th , so this would definitively be new!
How do you do the ST16 controller update? any videos?If you click on file/firmware update on the GUI you can choose the file you downloaded and it should update. Thats what it looks like, but like most here I am still waiting for mine, so hope this is right.
Thanks, it is done! What about ST16 zip, extract too? and I see no instructions to update controller firmware, man this sucks! LOLYes extract it , then click on the .ext file and install it.
The GUI should have installed the drivers.I need to install the GUI usb driver? I have my own USB drivers on my PC, and if I have a 64 , not 32 PC I install the 64 Driver correct?
Yes there is a warning and like 3 mouse clicks before they will spinView attachment 622
When using the speed controller status test, make sure props are off. I don,t know if a warning appears but this can ruin your day.
Crap! There is only a Windows version, no MAC version yet. I'll have to bring the old Windows VISTA laptop out of storage.The H GUI is back on the Yuneec web site.Downloads - Typhoon H
That I don't know, I would assume you extract it to an SD card ,place it in the ST-16 and power it up. Thats the way DJI controllers and many other controller update, but just speculating.
What I don't see is a download for the existing firmware is care you need to downgrade back to original, in case things don't work out. In my experience updates can some times blow up and brake things.
Just like on the Phantoms, check the version # to see if you have the latest already. So.... Here is a screen shot of the YUNEEC downloads web site. Notice the FIRMWARE version # for the TYPHOON and ST16. Start up your Controller & your TYPHOON. Go to the SETTINGS option on your ST16 and then click on ABOUT. If the FIRMWARE version #'s below (Version 3.01.b18 for Controller & Versions 1.22, 1.15, 3.1.37 for Typhoon) are not the same as what is showing on your controller, then you need the update. Pay close attention TO WHAT IT DOESN'T SAY BELOW... EACH (ST16 & TYPHOON) MUST HAVE LATEST FIRMWARE. My thoughts are to UPDATE the controller FIRST before updating the TYPHOON... Because the controller is used to update the Typhoon.Is the date 5/19/2016 I see above the firmware date? if so I received mine on 20th , so this would definitively be new!
I conected with the GUI and can play with everything, but can't update. The file is not downloading from PC to the TH.
At the moment I don't have a card adapter because our PC is a gaming one and cards are "not needed" (that waht my son says). I'm going to out to buy an adapter and will have it downloaded to the card, as the tutorial. Will post if it works.
