I flew my H pro yesterday and all was working fine took off and landed both manually and tried RTU which also worked fine several times. Tried out CCC, follow me and just flew around till first battery ran down. Changed to second fully charged battery and flew for a while and brought back to land manually. H was coming down smoothly and when touched down props did not idle down. I let go of the throttle stick and of course it started to bounce and try to take off. I held the left stick down again for about 15 seconds with no change. I then raised the left stick to raise the H and try to land a second time. After touching down and with the stick held in the down position for a few seconds the props finally went to idle speed and was able to shut down.
I was in angle mode, OA was off, RTH off, H had 19 sat's, st16 had 15 sat's.
It is a new typhoon and came with all updates from factory and ALL calibrations had been run. Both the H and st16 still had plenty of battery also.
Anyone have any idea's
