  1. Gurusonwheels
    Anyone have any idea what the
    Thrust is on the typhoon H
    Factory motor and prop.
  2. K3CFPV
    Monrovia, MD
    I just got a spare motor and prop adapters a few days ago. Have the motor mounted on my thrust stand. One problem I ran into is that Yuneec (again) did something different. The motors came with 1mm male bullet connectors already attached - nice. However, while most male bullet connectors have the bulged sides and the females have a smoother interior, Yuneec chose a smooth male. They are too loose to fit a standard female connector. I'd like to keep the motor as a spare so I don't want to change the ends. Before I can do my thrust measurements, I need to find the appropriate 1mm female connectors that mate firmly with the motor connectors. Hopefully soon. If anyone knows of a source, please let me know.
  3. BobW55
    BobW55 Have you place your map pin yet?
    Staff Member
    Melvin Michigan, In the thumb
    Small alligator clip would work for short testing, or just shove the wire in there.
  4. K3CFPV
    Monrovia, MD
    Made soom bullet adapters to keep the motor stock and got everything hooked up, so I decided to do some quick thrust measurements at 50% throttle (typical hover point) and 100% throttle.
    50% throttle, 4.2A, 49W, 12.0 oz, 5550 RPM
    100% throttle, 10.7A. 126W, 24.8 oz, 7600 RPM
    Rough calculations are 4.5# thrust at mid throttle (my H has a measured GTOW of 4.33#) so this seams reasonable. Also, total battery draw at hover would be around 25A (5C if you use 5400 mAh, 4C if 6300 mAh). At WOT, draw jumps to 64.2A (12C or 10C). Not a big load for even a half way decent battery.
    Also, doing the static thrust measurements for the prop (9" dia), I calculate a pitch of roughly 3.5.
    Plan to do more measurements and develop thrust curves later this week.
    #4 K3CFPV, Jul 9, 2016
  5. Gurusonwheels
    Thanks for the Intel .
    Sent from my LG-H830 using Tapatalk
  6. K3CFPV
    Monrovia, MD
    Ran a few more data points this morning and plotted Power (W) and Current (A) vs. Thrust (g). Let me know what other data would be helpful and I'll try to accomodate?
  7. K3CFPV
    Monrovia, MD
    Making a universal prop adapter and have some 9x4.3 and 9x4.7 props on order. Also looking at Graupners 9" tri-props. Will post data when I get the comparisons done.
  8. Castle972
  9. mcbutler
    PL4 8QB
  10. mcbutler
    PL4 8QB
    Glad you did it in g, most of the world has no idea what an oz is lol
  11. Tuna
    UK
    It'd be interesting to work out if you can get a reasonable estimate of power draw from the throttle position. I know once you're flying it's not static and would be much more inaccurate under windy conditions, but it would give a base line for expected battery performance and for telemetry analysis. I guess the real challenge would be reverse engineering what the IMU is doing in normal flight, as you don't get thrust values (or even a helpful proxy) in the telemetry.
    (I realise this is not remotely scientific, just thinking aloud!)
  12. PatR
    Home at last
    There are ways to do that but all of them require splicing equipment into the power supply feed. Easiest way might be to just record max current during a few flights. Incorporating a WattsUp into the system would be easy and light enough not to have much of an impact on power consumption. It would record max current value.
    An Eagle Tree data system could be used to record electrical data for an entire flight. More expensive than a WattsUp by a bunch.
