Does anyone know what the advantages the H920 has over the Typhoon H? For this discussion, I'm not referring to the cameras (CGO4 vs CGO3+), the CGO4 is clearly a better camera than the CGO3+. I looked up the price of the CGO4 and I saw a ~$2,700 price tag.
H920 Specs
Air Time 24 min
Diagonal Length Without Rotor Blades 36.2 in(920mm)
Propeller / Main Rotor Diameter 17.3 in (440mm)
Take-off Weight with GB603, GH4 Camera and Battery 176.0 oz (4990g)
Battery LiPo 6s 4000mAh 8C
Charger 100W 2 x output AC-DC Balancing Charger
Transmitter 16-channel 2.4GHz with 5.8GHz video downlink (included)
Flight Modes Waypoints, Orbit Me, Follow/Watch Me, Point of Interest, Journey, Smart, Curve Cable Cam, Angle and Home Modes
Maximum Flying Height (Absolute altitude) 4000m (13123 ft)
Maximum Flying Height (Relative altitude) 122m (400 ft)
Maximum Rotation Rate 100°/s
Maximum Roll Angle 35°
Maximum Horizontal Speed 40km/h
Radio Control Frequency Band 2.4GHz
Operating Temperature Range ﹣10℃ to 50℃
Typhoon H Specs
Flight Time Up to 25 min
Size 20.5x18x12.2 in (520x457x310mm)
Airframe Weight (with Battery) 59.8oz (1695g)
Take-off Weight 368.8oz (1950g )
Battery 4S 14.8V LiPo Battery (POWER 4)
Battery Capacity / Voltage 5400mAh 4S/14.8V(79.9Wh)
Charger SC4000-4
Transmitter ST16 Personal Station Ground
Maximum Flying Height 122m(400ft) agl (Restricted by FAA )
Maximum Rotation Rate 85 deg/s
Maximum Climbing Speed 5m/s
Maximum speed in follow me mode 43.5mph (70km/h)
Maximum Descending Speed 3m/s
H920 Specs
Air Time 24 min
Typhoon H Specs
Charger SC4000-4
