HEAR THIS ! Yuneec, people are cancelling pre orders on the H because you have lousy PR and can not even give us current information, and you do not respond to the DJI's lawsuit, which can lead to people thinking YOU are guilty, speak up or lose my order!
PLUS.....Check out and compare the specs of the P4 and the H. Yuneec classified the options of the FLIR / sensors / to different price brackets...
DJI has :
Vision system augmented to include two front-facing cameras used for both subject tracking and object detection / avoidance
Field of view: 60º vertical, 30º horizontal
Object detection at up to 15 meters (49.2 feet) away
DJI GO now shows an object detection visual indicator
100 grams (0.22 lbs) heavier
New battery: 5350 Mah, 15.2V battery (rated at 28 min flight time). Some flights from prototypes have been 30 mins or more.
Composite bottom for structural integrity
Micro-SD card and micro-USB port moved to body from gimbal plate
Camera uses same sensor, but has better glass lens and can do 1080/120fps
Motors have same propulsion specs but have been pushed out of the mount, which allows for better cooling
Grills for cooling vents on bottom of arms
Redundancy: dual IMUs and dual magnetometers (compasses)
New propellors (quick release)
Latches at end of each arm are for snap-on prop guards (which can obstruct vision sensors)
Flight modes revamped
Normal mode: manual flight per older Phantoms
Sport option (switch activated), which:
increases max pitch to 45º
increases max speed from 16 to 20 m/s (35.8 to 44.7 MPH)
increases max ascent and descent speed
Disables vision system
TapFly mode: tap on the live FPV screen, and the Phantom flies in that direction
ActiveTrack mode: follows an object you select in DJI GO
Smart mode: POI, Follow Me, Waypoints, Home Lock, Course Lock
MATCH THAT YUNEEC.....Funny because I started with the 5004K months back, despising DJI customer service. Not to worry, Peter at acesdeals.biz will fix any issues with the P4 or any Yuneec product.
6 prop redundancy with the H you say?... how often does one prop die in a quad anyway, or in a hex (if Yuneec would only release the H, we'd know) only if you do not properly mount the props. But the emphasis is just fly safe, do your pre-flight checks and all should be fine.
BTW, here is the H specs:
SPECS
The Typhoon H also maintains the Typhoon family’s focus on safety with features such as Geo-fencing, Variable Speed Control, Dynamic Return Home, Low-Battery Return Home and FAA No Fly ZONE.
Includes:
- Typhoon H, 6 rotor, retractable landing gear airframe
- Ultrasonic obstacle collision avoidance - CGO3+ 4K camera
- ST16 Ground Station
- 1 battery
- USB Charger
- LiPo battery charger
- Backpack-ready foam insert - Full color packaging
That's it folks !!!!
