Video reception
Dey
My typhoon g is new. 1st couple of flights reception for video . Go pro was fine.
It now cuts out at about 60 to 80 ft distance and only reconnects when very close to the controller.
I've checked the connections and did what I could look at with the settings.
It works when close but is slow, jittery.
Then cuts out at 60 ft.
Any ideas. Thx.
When I had the problem with my unit, it was due to a bad cable from the gimbal to the USB on the GoPro. That cable is very fragile. Once I got a new cable, the problem went away.
I've never gotten very good video range on the G. 500 - 700 feet is the best I've experienced. I get significantly better video range on my Q500 4K, up to 2000 feet on several occasions.
trepox
