I ended up buying the UP120AC for myself. I think it will cover all my needs for now and the near future.
I am no expert myself believe me. Still learning. I am assuming that the balance plug port can only monitor one at a time. I will read that tomorrow.
Yes, I charged 2 at the same time. I think the batteries are OK. They didn't even get warm. These batteries appear to be a little better than advertised, as has been reported in earlier threads. There's a 2.1 amp USB charge port that uses the same USB cable that came with the ST-16. The extra speed is better for me because I have 6 batteries to charge.
Thanks for that Info. After further review I too ordered the UP 120AC as the previously mentioned charger was only 80 watts.Already got the UP120AC. I wanted one with more output than the X2. I want to be able to charge 6 to 7 amps per battery at the same time. I also liked the duel screens to monitor each battery.
Unless a battery manufacturer states differently you should not charge at greater than a 1C rate. The H does not use a 7 amp hour battery so some of you are charging at too high a rate. The battery in the ST-16 is a different chemistry but should also charge at 1C or less. We all like to save time but charging at too high a rate will cost money in early battery replacements.
That's one of the reasons companies are going with the slow chargers. Forcing people to buy only their batteries is of course the other. People lacking experience and understanding of Lipos can obtain a charger than can get the job done faster through higher adjustable charge rates but are a lot more prone to causing battery fires. It's very hard to charge damage a Lipo when charging at 1/2C or less. If people lack that knowledge and understanding they should take a little time and learn about lipo battery chemistry, charge rates, storage levels, and how treat them in general. They are not a charge and forget type of battery, and how they are charged is extremely important to how long they last, how well they perform, and safety.
Some Lipos can be charged at higher than a 1C rate but those products typically have the manufacturer making that statement or have notes on the battery label. Lacking specific manufacturer information referencing charge rates higher than 1C, the safe route is to charge at 1C or less. Homes have burned down because of lipo fires and nobody needs or wants that.
Well that little quip can't go unchallenged. I've been using something like this HobbyKing Parallel charging Board for 6 packs 2~6S (XT-60) (EU Warehouse)Totally agree.
<snip>
Oh, and don't get me started on people that think using parallel balance charging boards are just as safe as a single balance charging board for each battery !!!!!!
1c would be 5.4 amps. Your charging at 1.03569c! LolI am happy charging 2 batteries at 1C (6Amps). I have temperature probes on both for added safety, never seen the temp go above 3 degrees over room temp. I am also using a computer interface so I can watch what is going on. Takes just about an hour for both.
The batteries aren't 5400mAh despite what's printed on the case. I think the CW around here is that they are at least 6000mAh (maybe even a little more?).1c would be 5.4 amps. Your charging at 1.03569c! Lol
I thought HAM radio was expensive.You just have to know what you're doing and understand charging. So what's the beef?
I hear ya. That comment was directed to abinder and not you, BTW. Always wanted to study HAM just to firm up my RC and communications skillset, but just can't seem to find the time with kids and my own business to attend to.LOL John,
Everytime I turn around there is some gizmo I need to make things better.
Well I'll see your Polaron charger and raise you one iCharger 406 Duo!love my Graupner Polaron charger
