What is the proper method of disposing a Lipo?
LiPo Battery Disposal
Before disposing of your LiPo, check to make sure the warranty has expired. Some companies have one-year replacement warranties that you can take advantage of, but most warranties will be voided if you perform the following steps before seeking a warranty replacement.
So you have a bad LiPo battery? No one really wants to keep them around (fire hazards that they are). So what is the process to get rid of a bad LiPo battery safely? Let's go through it.
  1. Discharge the LiPo battery as far down as you safely can. You can do this a number of ways. Most computerized LiPo chargers have a discharge feature in them. If you don't have a charger with a discharge feature, you can run down the battery in your vehicle - keep in mind that you risk a fire and potentially damaging your vehicle doing this, so take care to have the necessary safety equipment around. Alternatively, you can build your own discharge rig with a taillight bulb and some wire. Simply solder a male connector of your choosing to the tabs on a taillight bulb, and plug the battery in. Make sure to have the battery in a fireproof container while doing this.
  2. Place the LiPo in a salt water bath. Mix table salt into some warm (not hot) water. Keep adding salt until it will no longer dissolve in the water. Ensure that the wires are all entirely submerged. The salt water is very conductive, and it will essentially short out the battery, further discharging it. Leave the battery in the salt water bath for at least 24 hours.
  3. Check the voltage of the LiPo. If the voltage of the battery is 0.0V, great! Move onto the next step. Otherwise, put it back in the salt water bath for another 24 hours. Continue doing this until the battery reaches 0.0V.
  4. Dispose of the battery in the trash. That's right - unlike NiMH and NiCd batteries, LiPos are not hazardous to the environment. They can be thrown in the garbage with no problem.
Alternatively, if you don't feel like going through this process yourself, you can bring the battery in to us and we will dispose of it for you at no cost. If you're not in our area, check with your local hobby shop to see if they offer a similar service.
go to this site , A Guide to Understanding LiPo Batteries
Thanks!
I've generally removed the connectors, protected the ends of the wires, and taken them to the county landfill and placed them with other batteries being disposed of. Only reason for removing connectors was to reuse them.
I rang the local council waste disposal department and they said put them in the bin for battery recycling. I use a lamp to run them down and cut off the connectors and tape over the wires first.
Best Buy has a disposal policy that you can take Lipo to.
simsone
