Where to find camera base assembly replacement?
The plastic track in the camera base broke and is unrepairable. Also two pins which go through the rubber pieces between the two square bases fell off. the camera can't attach to the drone any more.
Does anyone sell the plastic base assembly? or do I have to get the whole camera plus base combo?
Is the base assembly unique to Typhoon H only or shared among other Yuneec drones.. or other drones from other companies?
If you found a cheap steady grip, I wonder if you could use it?
tmsmindspace
