  1. OnTheRopes
    Peak District, UK
    So, was testing the camera again today after some issues with losing wi-fi.
    Every time I boot up it takes 2 - 3 mins nefore I get the wifi and FPV. However during flying the camera was working fine, that was until I tried CCC again which was wher I was having problems yesterday.
    I set up the waypoints, the first being just 20 yardsd away and a second maybe 150 yards.
    Started the video, started to fly the wire and then lose wifi. Brought it back near me and it just hung trying to reconnect. Landed and the camera connected again. I tried ccc again and the same issue not more than 150 yds away and with clear line of sight?
  2. DroneClone
    Texas
    When lift off , are you getting the flashing green/white or purple /white led(angle mode) status? Or is it a solid color? Will only work in CC, poi, etc with good GPS?
  3. Subtle Shots
    Aliso Viejo southern California
    Video antenna on tight?
  4. OnTheRopes
    Peak District, UK
    Not sure about the status light, will check next time, I did have 20 satelleites though at the time. Antenna seems tight enough.
    DroneClone likes this.
  5. DroneClone
    Texas
    should be good to go with 20 satellites! Confirm lights next time you lift her off
  6. DroneClone
    Texas
    If you continue to have issues with that, call Yuneec tomorrow and let them walk you through a check list on your settings, that's all I would suggest, I hope you get it squared away real soon !:)
  7. Gyro108
    West Midlands, UK
    I'm also getting random disconnects, It has happened 300 ft away and 10 ft away, I'm wondering if it is because of the lower 5.8 output for the EU firmware.
  8. Dragonflyerthom
    Gurdon, Ar
    Look at the center wire on your mushroom antenna. If it is crooked or bent over it will act like that.
  9. OnTheRopes
    Peak District, UK
    All looks fine to me
  10. Dragonflyerthom
    Gurdon, Ar
    Ok go into the ST16 system settings, make sure the cog pro is selected in camera select then go to bind and tell me what you see there
    OnTheRopes likes this.
  11. OnTheRopes
    Peak District, UK
    OK
    Waited for camera to connect.
    Went to System Settings
    CGO3P was selected but was still available below to select if that makes sense.
    Selected and hit Bind. Had to re-enter password, got Connection failed
    Got blue flashing LED then connection failed again.
    Hit the back button and camera still working
  12. DroneClone
    Texas
    Camera still working, as in it's fixed?
  13. OnTheRopes
    Peak District, UK
    No
    It works fine most of the time, but when flying CCC it disconnects wifi and then the camera does not come back by which I mean no FPV or anything
    When I said Camera still working I was referring to followingDragonflyers suggestion above where I did not lose wifi, just messed with settings
  14. DroneClone
    Texas
    Call Yuneec tomorrow at 8 AM PST and they will do everything to get you connected again, it's very strange it does it only in CCC and other poi settings ! Does the CCC actually fly the route?
  15. OnTheRopes
    Peak District, UK
    Yes, Im going to try and get a few more flights in now and test it again before calling Yuneec in the morning.
  16. Dragonflyerthom
    Gurdon, Ar
    Is the camara still recording while wifi is dropping nout?
  17. Dragonflyerthom
    Gurdon, Ar
    Next as you look down at the ST16 which side is the mushroom antenna on? Right or left?
  18. OnTheRopes
    Peak District, UK
    Well just been out. First tried a distance flight while recording. managed to get out to around 3700 feet, wifi became erratic and the lag was so much that it was difficult to control pan or tilt.
    Then tried a ccc flight and managed to video the flight this time
    On another flight I lost wifi at around 400feet so I really don't know what it is.
    Took another long flight and took a few stills at distance.
    Mushroom on the right, I have just ordered one of these Yuneec Typhoon H LHCP with the 14dB upgrade, see if it helps or will I need the camera antenna
  19. Gyro108
    West Midlands, UK
    I've ordered one of those as well to see if it makes a difference.
  20. OnTheRopes
    Peak District, UK
    Fingers crossed
