Adjust camera angle in flight with controller?
Hi everyone, I'm new to flying the breeze. Is there a way to adjust the camera angle when the breeze is flying in pilot mode via controller?
Use the d-pad up/down. If you haven’t done it yet you probably need to do the firmware update on the controller. See this thread Breeze G3 Controller Update - Updated 07/17/2018. Download the update from the Yuneec link, then follow the directions at the 07/07/2018 section of that post.
If you hold the right trigger in there is a function map for the controller.
Thanks for the quick reply, did try that, doesn't work on my iPhone but does on my android so I'll update the software. Also on a side note I had my first crash today. Learned to only bind wifi on the ground from take off point. It took off and immediately raced to the left crashing into a solid object after about 50ft. Now I need new propeller guards. Just have to figure out where to find them.
CKHD
