Adjusting Gimbal Tilt Speed ST16S
Is there a way to adjust the GIMBAL TILT Speed on the slider switch? Seems the Gimbal Slider Switch on the Transmitter causes the Gimble to move too FAST!
Appreciate all replies!
DoomMeister
Moderator/Tech Junkie
Staff member
Premium Pilot
Genesee, MI USA
Place the Gimbal Tilt switch in the bottom position. The Tilt Slider will then be in Rate mode and when it is at midpoint the gimbal will retain its position. When moved up or down from the midpoint it will move in that direction proportional in speed to the distance moved away from the midpoint. Moving back to midpoint halts the movement.
DoomMeister
Staff member
Premium Pilot
Genesee, MI USA
This takes some practice to get good at using it, but allows for slow smooth reveals and other techniques where smooth gimbal pitch movement is needed.
New Threads
yingxoxo2022
