- Joined
- Jun 14, 2018
- Messages
- 225
- Reaction score
- 61
Oh the good ole shinnok , by the laws physic it’s not suppose to fly but it sure does . Spent many a hour in one of thouse noisey things . Always felt safe in it too
I encourage everyone to try the pumping kill button from about 8 feet to get used how long to hold the red button in for.I like short "How To" videos, but this must be the shortest yet. I like it. I never heard of that before.
Naturally I had to go try this. Went through one battery messing with it in a breeze of 6-8 mph. Took off and landed at least a dozen times.
Works great.
Works fine from 10' down (did not try higher), you just keep bumping the Red button and it drops a bit each time. You can still use the right stick to center the drone, but not when bumping the button. Touching the ground is OK, or 6 to 12 inches high, when you finally hold the Red button down and kill the motors. Notice on the video he did not try to center above the pad.
This is super! Maybe you should put it in the Help Sticky, Steve.
It responded the same for the H+ that I flew.It should be noted that this technique should only be attempted with the ST-16 or ST-16+, used with the Typhoon H or H Professional.
Do not attempt with the ST-16S used with the Typhoon H Plus or Typhoon H Plus Professional. The ST-16S does not respond to short clicks in the same manner.
This concludes this PSA... we return you to your normally scheduled program...
It did work for the +. I'm saying that maybe when you tried it that it didn't work as my 920 and 480 sometimes glitch on this issue. I'm assuming that you have tried it on your H.Thanks for the clarification... I thought you were saying that the Red Button technique did work for your H Plus.
The + I'm referring to is a friends. He did a lot of research into drones before purchasing. He was concerned about flying by himself for the first time so I went with. He wanted to do the pump method so I explained it to him and he experimented with it at about 8 feet.Ok, so now there is some conflicting information that needs to be resolved...
in @Ty Pilot 's thread below
First Impressions
He states that the Red Button Landing method does not work with the Plus, while your experience is the opposite. Or this behavioral change is due to the recent FW upgrade?
Unfortunately, I have not purchased my Plus as of yet, so I have no means of any investigative problem solving on my own, currently.
We did the RTL and the descent is very fast. We did not let it complete the landing but it went to the take off point each time which is nice to have in the bag of tools. We did the button thing at about 8 and 12 feet and since my friend was doing the controls I can't say if it's faster or slower but the RTL descent is much faster to the point of being scary.Having used the red button 'pump' method successfully many times on the 480, I thought I would try it on the Plus in exactly the same manner; typically I would let the aircraft settle at about two feet then two or three presses of the button would result in a landing.
When I tried this procedure on my Plus, the first tap dropped it all the way to the ground and I was just able to catch it. I also noted that the speed at which it dropped was more than double in my estimation. So, I raised back up to about three feet and tried again - same results. My findings at that time were that the decent speed was too fast and so different to the 480 that I would not use this method any further.
I would also note this was on the original firmware and perhaps this was one of the bugs that was fixed. Either way I have still not tried it as I am very happy with the landing habits of the Plus. Also I am now experimenting more with different tasks and the auto take-off and auto land are pretty good. The auto take off is seamless; once you swipe the start button it spools straight to a takeoff and lifts gently to about 12 feet. The landing is a little "carrier" like in that once initiated, it establishes a decent speed that I thought was a tad fast but let it go and it holds this speed till contact is made and the motors shut off clean.
build652_20180507 is the version that was on the + that the pumping worked to landSo perhaps the red button is fixed after the update.
This should not be used higher than 3' above the ground just to be safe.Somebody tried this "Red Button" landing from 10' altitude?
