Short version: Bad solder on battery connector.
TL;DR version: My Typhoon H480 died on me not too long ago. Wouldn't power on at all. I just assumed the power distribution board got fried for whatever reason. I ordered a new PDB and everything is well now.
I decided to investigate the original board that was installed on my Typhoon H and try to see what the problem was. All my fuses were fine, flight control was ok. Then I checked the wire and connector that plugs into the battery and this is what I find: a really bad job of a solder! There was barely any connection between the main power wire and metal battery plug! I have the version 05 board, the new board is version 07 and had a noticeably better solder job on the connectors.
I'm quite thankful that the bad solder didn't break apart in flight. I'm beginning to wonder if all the reports I've read of unexplained THs dropping from the sky is related to a bad solder job on the older versions of the boards.
If you have a version 05 board, check your solder points!
