Battery check query
Glasgow
Hi folks I put 2 of my other batteries on my DY3 when finished charging I noticed the amps look different should I be concerned I will be going out to fly in my local sports center as due to lock down would not get away with going to my usual spot I have uploaded a pic of the charger displayIMG_20200509_105743.jpeg
You should be fine. They are charged to 100% capacity. The readings for mAh are how much was added during the charge cycle. As a rough guess your batteries were stored around 60% capacity.
If it has been months since you used them keep a close eye on your voltage level while you fly. Better safe than sorry.
I have 4 batteries so try and cycle 2 at a time while the other 2 are in storage till I use them on the next flight I have a sticky note that I wrote use these next and place them on the 2 that's in storage
Hi folks I put 2 of my other batteries on my DY3 when finished charging I noticed the amps look different should I be concerned I will be going out to fly in my local sports center as due to lock down would not get away with going to my usual spot I have uploaded a pic of the charger displayView attachment 21756
Was one on the right charging interrupted? I can see only 11 minutes to fully charged, was it stored nearly fully charged?
  • Sad
Reactions: 7cyclops
I see 50 minutes 58 seconds on the left and 44 minutes 28 seconds on the right for amount of time spent charging.
Only a few seconds from when I noticed I never turned the other to charge no each time I come back from a flight I put in to storage mode I always land when battery shows 14.7 so I have never had the st16 beep with a battery low
I can't enlarge on my phone to see. It looks like 11 minutes, but I stand corrected.
Tap on the photo you want to view larger, this screen comes up, select the icon the arrow points to and the photo will open in a new browser tab. You can then pinch zoom to any level of enlargement. When done press the back arrow of your browser and select the X that is circled to exit the photo view.
It only really has problems this website, it renders the website fully enlarged or no zoom, the magnifying glass search played up until they fixed it 90% of sites are fine.
Just gone and looked on PC now. Yes 44 minutes, that's pretty quick still.
ThatsOneFriendlyMofo
