Just got an iPhone 8 and it will not link up to the Bluetooth fog controller. Everything else works great. Everything is updated. Tried resetting controller as well. Nothing works. Help please
If this is the first time you use the controller, you should get them paired first. Make sure your iPhone's Bluetooth is turned on and the turn on the controller. You should be able to see GameSir G3 or G3s. Connect the controller on the iPhone. Once they are paired, open the Breeze Cam app, switch to the FPV/controller mode, you should be able to see the "connected" message. You are done! Next time when you use the controller, just turn it on and then open the Breeze app, switch to the controller mode, it will automatically connect.
The design of this connection procedure is awkward - the connection happens in the app not the Bluetooth screen in your iPhone settings menu.
