Breeze contection problem
I got a new Breeze drone, but am having problems connecting it to my IPhone 6S. When I try to calibrate the drone it says insufficient battery charge. My IPhone shows 100% charge and the Breeze battery is fully charged also. What is the problem?
Update drone to latest firmware first with any new drone.
For this "insufficient battery charge", try turn off everything, phone, drone then connect again.
However, I would not recommend re-calibration based on my experience. Without calibration, my drone returned home 2-4 feet off the original take off point. After calibration in open field without any large metal object around, the RTH was 6-8ft off the original take off point. That happened to two drones so I stopped calibrating for any other. That's like "if it worked, don't fix." Updating to latest firmware is a sure way to get the latest and greatest in most cases.
Reactions: Scott DK
My 6s works fine after update( 9 jan2018) ,,, BUT .. cant get the controller to work even when it say “ connected “ :/
rubikonsgd
