- Joined
- Feb 20, 2018
- Messages
- 2
- Reaction score
- 0
- Age
- 58
The manual says Y is to "go home" but when it is pushed the drone skyrockets straight up. any ideas what I am doing wrong?
That's the way RTH works. The drone flies up to a preset altitude to get clearance from all, it flies horizontally to above the takeoff point then comes vertically down.The manual says Y is to "go home" but when it is pushed the drone skyrockets straight up. any ideas what I am doing wrong?
So taking off below branches of a tree should be avoided, got it! We started off under a tall tree with the first branches are 50-60' high and after Y was pushed it climbed above the tree and came down thru the branches. No damage but I worried, Thanks all!When you push the Y button it is returning to home but it goes above all objects before it returns home that's the reason to go straight up you have an adjustment on there's how far it goes straight up check that out in your in cam app
Is it safe to change flight task while the Breeze is airborne? Expecting my breeze to arrive next week. I am so excited to fly it the first time.
I'll keep that in mind. Thank youWhile in a hover you could change modes, but I personally would only do it with the Breeze on the ground.
