Blow them out with air or a proper contact cleaner. Do not ever use WD-40 on your investment. WD-40 is a lubricant and machine parts cleaner, an oil, and is a dust magnet. WD-40 will aslo cause the plastics to breakdown over time and become brittle. The oil left behind will with time make your problem worse.I having major trouble getting this to calibrate on the st16, the J4 and J3 aren't working properly as well, hardly moving.
Flushvision, thank you for the link. My sticks are still good but I've just used the link to order some 'cos I know I will need it sooner or later.WD40 also do a plastic safe electrical contact cleaner. There is absolutely no problem using WD 40 so long as it's the electrical contact cleaner variant.
as said above, though. Don't use the lubricant version.
https://www.amazon.co.uk/WD40-Drying-Contact-Cleaner-250ml
You're welcome.Flushvision, thank you for the link. My sticks are still good but I've just used the link to order some 'cos I know I will need it sooner or later.
Chers!
In the UK - East Sussex near the sunny(!) south coast.You're welcome.
Not sure where you are,Dilly. That link is for Amazon U.K. However, if in America, say, then I'm sure you will find similar through Amazon U.S.A.
Easiest thing first, a clean then a good stir, then see what happens.Well I read this post in bed yesterday morning then I went fly, but doing my pre flight checks I found an issue with J4
When I move the stick left to right the monitor shows a slow green motion, and not reaching the 100 percent mark. When the stick is back to centre the green marker gets there eventually..
Is it a clean up or new stick control...
Perhaps you'll have to invest in the Carbon fiber tray widely talked about on here.I have the backpack bag.
Club rules are, you can’t retrieve your craft on the strip with your controller in your hand.
The club field is the only place I can fly at the moment to tune in flight/camera skills, as well as ensuring the the H and controller is working correctly. 4 batteries gets used then its onto our race quads for a quick race, or may be unwind with a glider..
Lesson ( may be for all) is if I’m going to put any controller(s) on the ground. The little fans may suck the great outdoors in! Put something (bag?) down first..?
Yes it’s on the wish list... the ST16 is great but 4 eyelets?Perhaps you'll have to invest in the Carbon fiber tray widely talked about on here.
