calibration
After a firmware update, or if you see a compass warning frequently or an orange status light. I disregard the warning when I take off, raise or lower the gear or if I'm under 20' in altitude. The compass is sensitive and it's common to get a compass warning from ground effect.
Reactions: Ty Pilot
Actually, this question has come up several times. Search the forum for results.
I would add to what Steve Carr has said in that one should always calibrate the compass whenever you have traveled some distance away from the last place you flew the aircraft, or whenever you see any strange behavior regardless of whether you see any warnings.
drakemerch33
