Calibration
Hello, new pilot here. Just wondering if I'm supposed to calibrate my drone each time i turn it on or is that a one time thing? The instruction manual isn't clear on that. Thanks
There are tens of thousands of Q500's which have never been calibrated. However, you should do the calibrations at least once. If you travel several hundred miles you may need to calibrate the compass for the new location. Make sure the Q is on a level surface when you cal the accelerometers. If you notice it drifting in hover you may have to redo the cals.
Bdog
