cam quality, when sun goes down
with sun and full daylight the cam gives a good quality.
but when then sun goes down and you get in low light the sharpness is running away very fast...
maybe somebody have a trick how we can hold the sharpness in low light situation
and what i can do against the ghost artefacts in bad light situation. for example when i put iso to 800 and then shutter on 1/50 i get noisy ghosts and see the how the objects draw a ghost line in vids... that doesn't happen in gopro and not on phantom (don't want a phantom)
thanks for help
and i want in next update:
-last cam settings are saved
-trim control work in manual mode for iso and shutter speed
-manual white balance
-HDR series
-panopics with a stamp to see which pics belong to this pano
-ST10+ for team mode
-you can choose which controller control cam
-optimize cam for low light
Some have said that you need to frame the shot with less sky to get better exposure for the overall shot. Probably a dynamic range limitation on this cam? I'm sure a more knowledgeable member will post a useful suggestion. I like those shots btw, very nice.
Reactions: eric bee
playtime365
