Camera battery charging???
A little help..... Typhoon H. I'm curious as to how the battery for the camera is charged. Does it draw power from the Typhoon's battery or does it require charging using the USB off the charger system??? The manual doesn't address this.
The CGo3+ camera does not have a battery. It is powered from the Typhoon H battery.
Are you having a problem with your camera?
Thank you Sir! I don't believe there is any issues with my camera. Since the PoH doesn't specifically say how the camera is charged, I was guessing that it was powered by the H's power packs. I was just making sure that i didn't miss a 'memo'.....
Reactions: WTFDproject
I am looking to find out on h battery 5400mah 14.8
charge amp?
storage volt?
charged volt?
discharged volt?
site came up blank
mathewthomasmt
