Camera inout underbelly q500+
Ok here's the situation. I went to set up my q500+, which was and had been working great...until it didnt...
That being said, i went to hook up cg02+ to the underbelly only to find out that the insert which is suppose to cover the 4 pin connector where the camera plugs into the actual drone itself. Come to find out that when I touched the actual 4 pin connector with the video cable. When i did I heard the "sizzle" and smelled sulfur. I later found the actual piece that covers thst 4 pin video connector.
Okay, boneheaded, yes.. you may have guessed it by reading..
Is there anyway in God's green earth that I may be able to do to rectify ..or did I do something wrong to camera(cg02+) itself, or the 4 pin port,...or both which by the way is securely back on 4 pin video port
Hopefully the long drawn video, if it attached may help...or not...help from all, appreciated
♿-out
Zeedentclinic
