Did that work for you? The slider? Is that the on the right side that controls the speed of the drone?should be easy, move all the toggle switches to the up position ; then adjust the slider up....
its ok man, everyone has been there.I feel duhhhhh! I found the slider on the left side. I never knew it was there wow. Thank you for the info
Thanks I will do thatIf you calibrate the camera, it’s ok to do that with the slider all the way up. You must reboot the TH after that is completed as it will stop off center. The reboot gets the camera back to true forward. If you calibrate the ST, make sure the slider is in the middle at the “beep” spot.
